[ Sonarr ] Smart PVR for newsgroup users
Re: [ Sonarr ][ 3.0.9.1549.0] Smart PVR for newsgroup users
up to 3.0.9.1549.0 and added TOS5 version
godly
Post by godly »
When i search for a series i get an error: skyhook authentication failed, do you have a suggestion on how to fix this issue?
mikeyfrog
Post by mikeyfrog »
Having trouble with the indexer working, same indexer works fine in sonarr on my windows PC and on Radarr on the NAS. Not sure why I get an error on Sonarr only. Does this package need updated?
Trace log:
2023-07-06 05:35:06.3|Warn|Newznab|Unable to connect to indexer
[v3.0.10.1567] System.Net.WebException: DNS Name Resolution Failure: 'api.nzbgeek.info'
  at NzbDrone.Common.Http.Dispatchers.ManagedHttpDispatcher.GetResponse (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookies) [0x0015a] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\Dispatchers\ManagedHttpDispatcher.cs:95
  at NzbDrone.Common.Http.HttpClient.ExecuteRequest (NzbDrone.Common.Http.HttpRequest request, System.Net.CookieContainer cookieContainer) [0x00086] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:126
  at NzbDrone.Common.Http.HttpClient.Execute (NzbDrone.Common.Http.HttpRequest request) [0x00008] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:59
  at NzbDrone.Common.Http.HttpClient.Get (NzbDrone.Common.Http.HttpRequest request) [0x00007] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Http\HttpClient.cs:281
  at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.FetchCapabilities (NzbDrone.Core.Indexers.Newznab.NewznabSettings indexerSettings) [0x000a1] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:64
  at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider+<>c__DisplayClass4_0.<GetCapabilities>b__0 () [0x00000] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:36
  at NzbDrone.Common.Cache.Cached`1[T].Get (System.String key, System.Func`1[TResult] function, System.Nullable`1[T] lifeTime) [0x000b1] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Common\Cache\Cached.cs:104
  at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.GetCapabilities (NzbDrone.Core.Indexers.Newznab.NewznabSettings indexerSettings) [0x00020] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:36
  at NzbDrone.Core.Indexers.Newznab.Newznab.get_PageSize () [0x00000] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Newznab\Newznab.cs:24
  at NzbDrone.Core.Indexers.Newznab.Newznab.GetRequestGenerator () [0x00000] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Newznab\Newznab.cs:28
  at NzbDrone.Core.Indexers.HttpIndexerBase`1[TSettings].TestConnection () [0x00007] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\HttpIndexerBase.cs:336
2023-07-06 05:35:06.3|Trace|SonarrErrorPipeline|Handling Exception
2023-07-06 05:35:06.3|Warn|SonarrErrorPipeline|Invalid request Validation failed:
 -- : Unable to connect to indexer, check the log for more details
2023-07-06 05:35:06.3|Trace|Http|Res: 97 [POST] /api/v3/indexer/test: 400.BadRequest (34 ms)
2023-07-06 05:35:06.3|Debug|Api|[POST] /api/v3/indexer/test: 400.BadRequest (34 ms)
2023-07-06 05:35:09.5|Trace|Http|Req: 98 [POST] /api/v3/indexer (from 192.168.10.4 Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36)
2023-07-06 05:35:09.5|Trace|Owin|SQLite error (5): database is locked in "PRAGMA cache_size=-10000"
2023-07-06 05:35:09.6|Trace|HttpClient|Req: [GET] https://api.nzbgeek.info/api?t=caps&apikey=(removed)
2023-07-06 05:35:09.6|Trace|ConfigService|Using default config value for 'proxyenabled' defaultValue:'False'
2023-07-06 05:35:09.6|Debug|NewznabCapabilitiesProvider|Failed to get newznab api capabilities from https://api.nzbgeek.info
  at NzbDrone.Core.Indexers.Newznab.NewznabCapabilitiesProvider.FetchCapabilities (NzbDrone.Core.Indexers.Newznab.NewznabSettings indexerSettings) [0x0006f] in C:\BuildAgent\work\63739567f01dbcc2\src\NzbDrone.Core\Indexers\Newznab\NewznabCapabilitiesProvider.cs:59
Sponge
Post by Sponge »
Had the same issue today as well.
Searching the net come accross people talking about certificates expiring through the mod addon so maybe this needs to be fixed or looked at
But
Had someone suggest in sonarr settings in general settings change
Certificate Validation to Disabled
This has worked for me now not sure on whether that is dagerouus to change allowing maybe others to exploit things but untill I find another fix this will work for me. use at own risk
Would be happy if others commented on here or other solutions.
download and install the latest version from tmnascommunity
