TOS 7.0.1225 (ARM) Official Release Update
EriChan
Re: TOS 7.0.1225 (ARM) Official Release Update
Post by EriChan »
iindeec wrote: ↑01 Oct 2026, 20:17
Thank you for the feedback.
We will continue to monitor the situation and attempt to reproduce the issue you mentioned.
iindeec
Post by iindeec »
Maybe this helps - got log for iSCSIManager unit
Oct 05 16:22:10 TNAS-Indeec systemd[1]: Stopping iSCSIManager.service...
Oct 05 16:22:10 TNAS-Indeec systemd[1]: iSCSIManager.service: Deactivated successfully.
Oct 05 16:22:10 TNAS-Indeec systemd[1]: iSCSIManager.service: Unit process 5862 (iscsimanager) remains running after unit stopped.
Oct 05 16:22:10 TNAS-Indeec systemd[1]: Stopped iSCSIManager.service.
Oct 05 16:22:10 TNAS-Indeec systemd[1]: iSCSIManager.service: Consumed 12min 37.950s CPU time.
Oct 05 16:22:10 TNAS-Indeec systemd[1]: iSCSIManager.service: Found left-over process 5862 (iscsimanager) in control group while starting unit. Ignoring.
Oct 05 16:22:10 TNAS-Indeec systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Oct 05 16:22:10 TNAS-Indeec systemd[1]: Starting iSCSIManager.service...
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247881]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/scst.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247882]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/iscsi-scst.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247883]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/scst_local.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247884]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/isert-scst.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247885]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/ib_srpt.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247886]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/fcst.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247887]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/dev_handlers/scst_cdrom.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247888]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/dev_handlers/scst_changer.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247889]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/dev_handlers/scst_disk.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247890]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/dev_handlers/scst_modisk.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247891]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/dev_handlers/scst_processor.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247892]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/dev_handlers/scst_raid.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247893]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/dev_handlers/scst_tape.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247894]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/dev_handlers/scst_user.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247895]: insmod: ERROR: could not insert module /lib/modules/5.10.107/extra/dev_handlers/scst_vdisk.ko: File exists
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247897]: parse error: Objects must consist of key:value pairs at line 79, column 23
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247868]: /etc/init.d/iSCSIManager: line 46: [: too many arguments
Oct 05 16:22:10 TNAS-Indeec iSCSIManager[247900]: /etc/init.d/iSCSIManager: line 63: /usr/sbin/iscsi-scstd: No such file or directory
Oct 05 16:22:11 TNAS-Indeec iSCSIManager[247901]: Config file format error!
Oct 05 16:22:12 TNAS-Indeec iSCSIManager[247868]: /etc/init.d/iSCSIManager: line 65: /sys/kernel/scst_tgt/targets/iscsi/enabled: Permission denied
Oct 05 16:22:12 TNAS-Indeec iSCSIManager[247906]: iSCSIDaemon is running
Oct 05 16:22:13 TNAS-Indeec iSCSIManager[247868]: iSCSIManager is stopped!
Oct 05 16:22:13 TNAS-Indeec iSCSIManager[247868]: iSCSIDaemon is running
Oct 05 16:22:13 TNAS-Indeec systemd[1]: Started iSCSIManager.service.
EriChan
Post by EriChan »
iindeec wrote: ↑05 Oct 2026, 19:26
Thank you for your feedback!
We have confirmed that the issue does exist and have escalated it to our product team for evaluation of potential improvements in future updates. Thank you again for your patience and understanding!
EriChan
Post by EriChan »
hk87 wrote: ↑28 Sep 2026, 15:58
We would like to let you know that TOS 7.0.1298 (ARM) has now been officially released, which fixes the issue where certain beta versions of the system could not update properly.
We recommend manually updating to TOS 7.0.1298 and letting us know if the upgrade goes smoothly.
Thank you for your patience and support!
krissan
Poland
Post by krissan »
Hey,
if you are somehow familiar with terminal, grab fully functional iSCSI export bash implementation: https://github.com/kodxpl/Terramaster-ARM-TOS7-iSCSI
