How to manually install 3rd Party Apps and the list with available apps
This post to explain how to install 3rd Party Apps (not officially supported by TerraMaster).
First of all, use them at your own risk and consider that Terramaster or OutkastM is not responsible for any possible damage or data loss.
These modules are developed and can be installed on TOS: 4.1.2.7 or later version
To manually install a .tpk package, within TOS WebUI go to Applications > Settings > Browse your computer to select the downloaded .tpk package and press Apply. After installation, an icon will be created on TOS desktop from where you can select additional option for the newly installed app. Do not close the installation window before the app icon is created on the desktop. Usually it takes maximum 10 seconds after installation is done.
The webpage for additional options (start/stop the module, enable/disable autostart, view log, edit config etc) is available only if you connect to TOS with administrator account
Apps will presented like this
For TOS4.x
x.64 - last version - 3.0.4.1042.0 // the .tpk filename will contain TOS4 and x86_64 as example ModBase1_V1.00.00_x86_64.tpk
armv8 - last version - 3.0.4.1042.0 // the .tpk filename will contain TOS4 and aarch64 as example ModBase1_V1.00.00_aarch64.tpk
For TOS5.x
x.64 - last version - 3.0.4.1042.0 // the .tpk filename will contain TOS5 and x86_64 as example ModBase1 TOS5 1.00.00 x86_64.tpk
armv8.2 - last version - 3.0.4.1042.0 // the .tpk filename will contain TOS5 and aarch64 as example ModBase1 TOS5 1.00.00 aarch64.tpk
For TOS6.x
x.64 - last version - 3.0.4.1042.0 // the .tpk filename will contain TOS6 and x86_64 as example ModBase1 TOS6 1.00.00 x86_64.tpk
armv8.2 - last version - 3.0.4.1042.0 // the .tpk filename will contain TOS6 and aarch64 as example ModBase1 TOS6 1.00.00 aarch64.tpk
x.64 product serie
TOS4: https://tmnascommunity.eu/downloads/tos4-x64/
TOS5: https://tmnascommunity.eu/downloads/tos5-x64/
TOS6: https://tmnascommunity.eu/downloads/tos6-x64/
F2-221
F4-221
F2-42x
F4-42x
F5-221
F4-222
F5-422
F8-422
F4-423
F2-424
F4-424
F6-424
F2-425 (Plus)
F4-425 (Plus)
armv8 product series
TOS4: https://tmnascommunity.eu/downloads/tos4-arm/
F2-210
F4-210
armv8.2 product series
TOS5: https://tmnascommunity.eu/downloads/tos5-arm/
F2-212
F4-212
U4-212
Available packages on:
tmnascommunity.eu
JayBlingham
Re: How to manually install 3rd Party Apps
Post by JayBlingham »
This is a shout-out to @OutkastM to say thank you for packaging these apps, and helping to expand the functionality of our Terra-Master NAS devices. You're doing exactly what I wish I had the talent to do, and for that you have my both my thanks, and envy.
Jay
F5-221 NAS
D5 Hybrid DAS
Thx for your feedback
Daywalker
France
Post by Daywalker »
I try to install apache python and sabnzbd with this package on F5-221 TOS 4.2.09 and I have an error.
Please help me
thanks
F5-422
On which moment you receive this message ?
Have you tried also to reboot the NAS ?
Daywalker
France
Post by Daywalker »
thanks
it happen when i click apply and after 50% processing
and i try after reboot nas
F5-422
Hmmm
I can't reproduce this.
I even did a clean install of TOS (to remove any of my possible manual changes), and no issue to install theese packages.
Maybe you can tru also with another browser ?
Daywalker
France
Post by Daywalker »
I try with two different computer one pc and one Mac.
on pc i try with chrome and i have the issue
on Mac I try with safari and chrome and I have the same issue
F5-422
I think i found the issue.
Is because your TOS language is set to French and all my tests were done on English language.
I will check what i can do.
You can download again the latest version from server (Python38 and Sabnzbd3) and install them.
Language issue will be fixed for other packages asap.
