TOS 7.0.0500 Beta (X86) is Released for Update
Target Users:
Users currently running TOS 7.0.0299 beta or later versions.
Note:
If your TOS version is TOS 6, please refer to the TOS 7 beta update instructions first
Here, we sincerely thank users@Joesh、@snapsh0t、@Gremlin、@rfbjr、@emperorgr、@Nitrokalel、@OttO1916、@Gravitator、and others, for their sharing and feedback. It is your support that has enabled us to quickly identify and resolve some issues.
Update Notes
Bugs fixes:
1. Fixed an issue where the terminal might throw an EFI error.
2. Fixed an issue where CPU sorting and memory sorting in Services & Processes might not work properly.
3. Fixed an issue where the timeline position was not remembered after enabling continuous monitoring for the first time.
4. Fixed an issue where the Beta label was unclear in Dark mode.
5. Fixed an issue where the marquee effect was missing for the backing up status in Backup Center tasks.
6. Fixed an issue where a download button appeared when installing a Docker application.
7. Fixed an issue where an array in DAS might not mount properly after rebooting the system.
8. Fixed other known issues.
9. Optimized the data loading logic for real-time monitoring and continuous monitoring in Resource Monitoring.
Important Information:
Update Procedure:
Client Downloads:
1. Download TNAS PC 5.2.520 for Windows OS.
2. Download TNAS PC 5.2.520 for macOS (x86 and ARM architectures).
3. Download TNAS PC 5.2.520 for macOS (ARM architecture).
4. Download TNAS PC for Linux.
5. Download TNAS Mobile 3.X for Android.
6. For iOS, experience TNAS Mobile 3.X via: https://testflight.apple.com/join/wFWYABJS.
rfbjr
Re: TOS 7.0.0500 Beta (X86) is Released for Update
Post by rfbjr »
All three of my devices updated fine.
One quirk, after I logon after the update (happened on all three)
An upload dialog box appears.
UPDATE: It happens after every logon, I just close the box and continue on.
Testing later today
F4-424 Pro also at 7.0.0777
D4-320
nedhedrick
Post by nedhedrick »
Update 7.0.0500 applied on F5-221. Only observed issue was numerous messages "Failed to retrieve data" on restart. Everything appears to be working, though.
A re-boot a few minutes later displays no such errors.
DCCentR
Post by DCCentR »
Docker Engine and Docker Manager was disabled for me after reboot
F4-424 Pro
snapsh0t
Post by snapsh0t »
Successful update here with no spurious messages. The system log refresh error that DCCentR reported has been fixed.
mnewland
Post by mnewland »
T6-423 updated successfully - no issues or errors seen so far from this update.
My TNAS
  • Device = T6-423
  • RAM = 32gb official Terramaster ram
  • Disks = 3 x Seagate IronWolf ST400VN006 4TB
  • TOS = 7.0.0765
  • BIOS = 5.19
  • Mobile App = 3.5.0.77
F2-425+ Updated: Numerous "Failed to retrieve data" on first login. Cleared after further reboot.
F2-221 Updated: Nothing observed (Got distracted :lol:) Reboot anyway - all ok.
Nitrokalel
Mexico
Post by Nitrokalel »
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, beta) update OK
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, beta) update OK
F2-423 (2x18TB, TRaid, 32GB, beta) update OK
F2-221 (6TB+10TB, TRaid, 10GB, beta) update OK
D1 SSD (2TB, prod) OK Los Nases reconocen bien al DAS
without any apparent problems or inconveniences
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod)
D1 SSD (2TB, prod)
OttO1916
Netherlands
Post by OttO1916 »
f2-221 and f5-221 updated without any real issues. Good job.
One minor thingy: on my f5-221 the AppCenter icon kept showing 2 updates available, but when opening the app center there were none.
After a reboot no more messages.
F5-221 - TOS7.0.0765 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.0765 - 2x3TB JBOD - 1x4TB Single USB
joka388
Austria
Post by joka388 »
Updated on F2-221 and F4-425, no Problems. Only on first boot i got this massages on both NAS
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
