[Help] Time Zone and scheduled task  [SOLVED]
rfbjr
Post by rfbjr »
My F4-424 Pro (I believe was set to Lima Peru time zone, not EST) Manually fixed that. Daylight saving time started March 8th.
The issue is below and no idea if related.
My empty trash task is off by an hour and discrepancy within the details. Supposed to be 8:50AM each day
Summary shows 9:50 but if you edit the task, it shows 8:50.
I didn't try deleting the task and recreate it.
Also, all three NAS were shutdown for a week (vacation) and were not running during the time change.
F4-424 Pro also at 7.0.0777
D4-320
MikeZhang
Re: [Help] Time Zone and scheduled task
Post by MikeZhang »
rfbjr wrote: 12 Mar 2026, 21:45
Please double check if your time zone is set to Lima, restart your NAS and start the task, check if the next run is still from 9:50. We have tested many times at our end, this issue can't be reproduced at the moment.
rfbjr
Post by rfbjr »
Will do that right now and report back later
D4-320
rfbjr
Post by rfbjr »
When in doubt, reboot.
Time zone was not Lima, but after the reboot, the job detail showed 8:50AM, the correct time. Will confirm in ~3hrs if job runs at 8:50AM but it should. :)
D4-320
rfbjr
Re: [Help] Time Zone and scheduled task  [SOLVED]
Post by rfbjr »
rfbjr wrote: 13 Mar 2026, 18:13 Will do that right now and report back later
Scheduled task ran at the correct time.
If this was a ticket, you can close it. :)
D4-320
