[Help] TerraMaster F4-425 Plus – random hard power-off under disk load (TOS 6 / TrueNAS SCALE)
tiem
Post by tiem »
Hello.
I am experiencing random hard power-offs on my TerraMaster F4-425 Plus.
The shutdowns happen under disk I/O load, for example:
  • large data transfers
  • photo processing (Immich)
  • torrent downloads
  • backup jobs
Observed behavior
During normal operation the NAS suddenly powers off without any warning:
  1. HDDs stop immediately
  2. cooling fan stops
  3. front panel LEDs remain ON
  4. device automatically powers on again
This looks like a hardware-level power cut, not a clean shutdown or kernel panic.
Logs
  • Code: Select all
    dmesg -T
    — only contains logs after reboot, nothing suspicious
  • Code: Select all
    journalctl -b -1 -e
    — previous session log ends abruptly, no errors before crash
  • Code: Select all
    last reboot
    shows frequent unclean reboots
root@truenas[~]# last reboot
reboot   system boot  6.12.33-producti Thu Jan  1 11:18   still running
reboot   system boot  6.12.33-producti Thu Jan  1 05:49   still running
reboot   system boot  6.12.33-producti Thu Jan  1 05:20   still running
reboot   system boot  6.12.33-producti Thu Jan  1 04:50   still running
reboot   system boot  6.12.33-producti Thu Jan  1 03:46   still running
reboot   system boot  6.12.33-producti Thu Jan  1 03:18   still running
reboot   system boot  6.12.33-producti Thu Jan  1 02:51   still running
reboot   system boot  6.12.33-producti Thu Jan  1 02:46   still running
reboot   system boot  6.12.33-producti Thu Jan  1 02:20   still running
reboot   system boot  6.12.33-producti Thu Jan  1 02:15   still running
reboot   system boot  6.12.33-producti Thu Jan  1 01:48   still running
reboot   system boot  6.12.33-producti Wed Dec 31 21:41   still running
reboot   system boot  6.12.33-producti Wed Dec 31 06:01   still running
reboot   system boot  6.12.33-producti Wed Dec 31 04:41   still running
reboot   system boot  6.12.33-producti Wed Dec 31 04:35   still running
reboot   system boot  6.12.33-producti Wed Dec 31 04:30   still running
reboot   system boot  6.12.33-producti Wed Dec 31 04:27   still running
reboot   system boot  6.12.33-producti Wed Dec 31 01:40   still running
reboot   system boot  6.12.33-producti Mon Dec 29 19:39 - 01:39 (1+06:00)
reboot   system boot  6.12.33-producti Mon Dec 29 04:26 - 01:39 (1+21:13)
reboot   system boot  6.12.33-producti Mon Dec 29 03:48 - 01:39 (1+21:51)
reboot   system boot  6.12.33-producti Mon Dec 29 03:41 - 01:39 (1+21:58)
reboot   system boot  6.12.33-producti Mon Dec 29 02:50 - 01:39 (1+22:49)
reboot   system boot  6.12.33-producti Sun Dec 28 23:16 - 00:22  (01:05)
reboot   system boot  6.12.33-producti Sun Dec 28 22:48 - 23:11  (00:22)
reboot   system boot  6.12.33-producti Sun Dec 28 22:20 - 23:11  (00:51)
reboot   system boot  6.12.33-producti Sun Dec 28 21:28 - 23:11  (01:42)
reboot   system boot  6.12.33-producti Sun Dec 28 20:57 - 21:27  (00:29)
Hardware / configuration
  • Model: TerraMaster F4-425 Plus
  • CPU: Intel N150
  • RAM: stock configuration
  • System drive: separate SSD (not part of data pool)
    • previously: Samsung 980 Pro (PCIe 4.0)
    • replaced with: new PCIe 3.0 SSD to reduce temperature
  • Data drives: separate HDDs (Toshiba 4 TB (MG03ACA400) and Toshiba 6 TB (MG04ACA600E))
  • Temperatures:
    • CPU: max ~70°C
    • HDDs: max ~50°C
Memory usage does not correlate with crashes.
Operating systems tested
  • Originally running TOS 6
  • To rule out OS issues, the system was fully reinstalled with TrueNAS SCALE
  • The problem is identical on both operating systems
This strongly suggests the issue is not OS-related.
Assumptions
Based on the symptoms, possible causes may be:
  • BIOS / firmware issue
  • power delivery (PSU / VRM)
  • hardware instability under I/O load
  • CPU power management (C-states)
Questions
  • Are similar issues known for the F4-425 Plus?
  • Are there BIOS or firmware updates planned?
  • What additional logs or tests can I provide to help with diagnosis?
Thank you.
Re: [Help] TerraMaster F4-425 Plus – random hard power-off under disk load (TOS 6 / TrueNAS SCALE)
Please first check the hard disk and CPU. Additionally, please generate and download the log report in TOS > Technical Support > Issue Report, then send it to our technical support email ([email protected]). We will analyze it. Also, include the link to this post in the body of the email.
