[Help] [TOS 6] SSH Key Authentication Fails Due to Home Directory Permissions?
gustang
Post by gustang »
Hi everyone,
I'm currently using a TNAS running TOS 6 and ran into an issue when trying to connect via SSH using an RSA key.
Details:
The same SSH key works fine on other systems (VPS, Synology, etc.).
On TerraMaster, the connection fails with:
Authentication refused: bad ownership or modes for directory /home/username
I noticed that the user home directory is created with 777 permissions and includes ACL (indicated by a +).
After manually running:
chmod 755 /home/username
→ SSH key login works as expected.
I'm wondering:
- Is this the default behavior in TOS 6 when creating new (admin) users?
- Is there an official way to use SSH key authentication without manually changing permissions?
Would appreciate any insights or suggestions from the team and community.
Thanks in advance!
MikeZhang
Re: [Help] [TOS 6] SSH Key Authentication Fails Due to Home Directory Permissions?
Post by MikeZhang »
1. The user created when reinstalling the system is a root user by default. Subsequent users need to be manually granted administrator privileges in the TOS system. The default privileges are ordinary user privileges.
2. No
Return to “Network”
