[Help] LDAP Client Setup
pongo
Austria
Post by pongo »
I am trying to setup ldap client based on https://github.com/lldap/lldap running inside TOS 6.0 docker on F4-423
But getting check dns records network blocked?
Any idea to fix this?
MikeZhang
Re: [Help] LDAP Client Setup
Post by MikeZhang »
pongo wrote: 09 Jun 2025, 23:45
Hi, would you like to change DNS to 8.8.8.8 then try again?
eavn
Vietnam
Post by eavn »
pongo wrote: 09 Jun 2025, 23:45 Hello,
I use Synology LDAP Server instead of LLDAP. However, it appears that the LDAP Client on TM does not support LDAPS. When I enable the "Require secure/encrypted connection" option on the LDAP Server, TM reports a "Network Blocked" error. Removing this option allows the connection to succeed.
Hope this helps.
eavn wrote: 20 Jun 2025, 14:32
Please tell us your NAS model and TOS version. We will verify it.
gustang
Post by gustang »
TMzethar wrote: 20 Jun 2025, 18:33
Thank you @TMzethar.
We test with various TNAS (F4-424/F4-424 Pro/F8-SSD Plus and now T9-500 Pro) and all TOS6 from beginning, now lastest TOS6 updated
We also tests and ruled out certain cases. When enabling the "force clients to use Encrypted connections" option, the applications we use (Snipe-IT, Portainer, pGina, etc.) can still connect normally to the Synology LDAP Server via LDAPS:// (port 636). However, TNAS cannot connect (Network Blocked error) unless we disable the "force clients to use encrypted connections" option.
Return to “Privileges”
