Thanks. I solved when returned home under wifi. But an answer please. Emby free is not acxessible feom remote? Why sometimes work well?IrisLi wrote: ↑02 Jun 2025, 17:47 What is your system version and model?
1. Confirm that Emby is running on TNAS. You can go to the App Center-Installed Modules to check whether Emby is enabled.
2. Try to connect to the server manually. First, make sure that the phone and NAS are in the same LAN. Enter the server IP address + port number to connect. To find the server address, just open the Emby server management interface on the Emby server device (usually accessed through http://localhost:8096).
This may be due to the fact that the public IP is dynamic (changes frequently):
Thank you. Please i have ddns address built with fritzbox. Is possible and simply set so? Thanks againIrisLi wrote: ↑02 Jun 2025, 21:56This may be due to the fact that the public IP is dynamic (changes frequently):
Many home networks have public IPs that change, and not setting up DDNS can cause access failure.
It is also possible that the port mapping failed after a NAS or router reboot:
Some devices may need to reconfigure port mapping after a reboot.
Yes, it could, theoretically, but we have not tried it relevantly. Perhaps the following emby connection information might help you:
