Downgrade TOS software?
Tricky
Post by Tricky » 01 Aug 2020, 21:23
Can this be done without having to completely reinstall and potentially loose data? and if so how...i just get the message that the software i am trying to load is lowed than that installed and cant proceed?
DiscoSi
Re: Downgrade TOS software?
Post by DiscoSi » 02 Aug 2020, 02:30
I've done it but I had a backup of all the important data first so it wouldn't have been the end of the world if it'd gone wrong.
If I recall it was a case of doing a restore to factory defaults, then following the initial setup process, you'll get warned that the data is going to be overwritten but I found mine was still there and just the actual TOS install was overwritten and set up from scratch. If you don't have a backup though then don't risk it!
F5-221 TOS 4.2.02 beta 4x4TB Seagate Ironwolf, 1x240GB Ironwolf SSD (Cache)
DiscoSi
Post by DiscoSi » 02 Aug 2020, 02:35
An official response is in the last post on page 1 of this thread:
viewtopic.php?f=21&t=674
But it does still come with some risk, so a backup would be essential if you ask me.
Tricky
Post by Tricky » 02 Aug 2020, 05:26
Mind you we wouldn't have to consider it if they would just release stable software that works is it me or is Terramaster the only company that does this? :roll:
Customer Service
Post by TMSupport » 03 Aug 2020, 15:26
It could not be done as you requested. Only re-installation could roll back to the former version.
