How do I know Raid 1 is actually working?
itsmikeski
Australia
Post by itsmikeski »
Quick question,
I've set up a Raid 1 with 2x 20tb IronWolf drives.
TOS only shows Volume 1. How do I know that the second HDD is actually mirroring the first? I guess I just want some assurance, but I cant seem to even check how much space is used on each individual HDD, only on the total volume (20tb as the second 20tb is obviously the mirror).
Re: How do I know Raid 1 is actually working?
If you go to Control Panel > Storage Pool; Highlight the pool you are concerned with; click on the 'down chevron' in top right of highlighted area.
This will show the HDDs being used and the Volume(s) mounted on that array. Naturally, if you have set up Raid1 (or Traid on 2 Drives) using similar sized drives the amount of space used will be the same for each HDD. (Or, it will be the size of the smaller drive and the rest of the space on the larger drive(s) will be inaccessible - that's sort of how raid works.)
itsmikeski
Australia
Gremlin wrote: ↑22 Aug 2024, 16:55 If you go to Control Panel > Storage Pool; Highlight the pool you are concerned with; click on the 'down chevron' in top right of highlighted area.
Thanks. I guess my point is there's nothing to actually show that the files on HDD2 have mirrored HDD1. It would help if we could see used space on both drives, just to confirm it's the same.
This is what I see:
If the used space were different you would get a "broken raid" warning.
{{I suppose (being raid 1) you could remove one disk at a time to prove that both would work on their own. I suppose that at some time or another most of us that are curious have done that, but why waste time and effort rebuilding the arrays [i]twice[/i] (and there is always a risk in doing that)}}
DigitalAnalog
Australia
Post by DigitalAnalog »
Pull one drive out and check that all your files are still there and then put the drive back in. No need to worry, your data is in safe hands with the TerraMaster OS. ;)
F4-423
genoasvelte
Bangladesh
Post by genoasvelte »
DigitalAnalog wrote: ↑23 Aug 2024, 21:44 Pull one drive out and check that all your files are still there and then put the drive back in. No need to worry, your data is in safe hands with the TerraMaster OS. ;) geometry dash
So how do you know for sure that your data source will be safe with the TerraMaster OS? Is there another way without having to remove the drive?
genoasvelte wrote: ↑01 Oct 2024, 10:24
[/quote]
Make backups, just like with any other system. Then 'test restore' from the backup to another drive in order to make sure that backup works. No system is 100% "safe".
