Centralized Backup - Backup Task Time Issue
UncleJohnsBand
Post by UncleJohnsBand »
Trying out the Centralized Backup. I noticed that when setting up the schedule I selected 01:15 for the schedule to run. i.e. 1:15 a.m.
After the task was created I noted the time ended up being 13:15 or 1:15 pm.
I edited the task and set the time to be 13:15 and sure enough it then was saved as 1:15 a.m.
However, the folder that is created for the backup showed the 13 hour and not the 01 hour.
2024-05-05-Backup Folder Image.png (2.69 KiB) Viewed 140 times
I am just reporting that the time you set in the backup task is not aligning with what gets saved.... it gets reversed from a.m. to p.m. military time.
The backup I ran was for a Hyper-V on one of the machines on my network and I had no issue (other than needing to activate remote management on the machine) with the backup.
Remote Management Enablement:
https://learn.microsoft.com/en-us/windo ... management
I also added a Windows backup, same issue on schedule. I did a run now at 12:41 p.m. and this is the folder that was created.... 12:41 a.m.
2024-05-05-Backup Folder Image-Windows.png (2.57 KiB) Viewed 140 times
Return to “Others”
