ClamAV can not enable real time protection
epsilonion
Post by epsilonion »
TOS Version: 5.1.67
ClamAV will not enable real time protection, it says operation failed, I hope terra-master can reach out to them and get them to fix the app..
TMtina
Re: ClamAV can not enable real time protection
Post by TMtina »
We will verify this issue.
FYI realtime protection appears to work (can be enabled) in latest versions 0of 5.1 and 6.0. The thing I notice is that it will disable itself on shutdown/reboot in TOS6.0
Gremlin wrote: 11 Apr 2024, 06:11
We have noticed the relevant issue and are currently investigating it.
Return to “Others”
