Wifi Frequency
MagicPhotoEvents
France
Wifi Frequency
Post by MagicPhotoEvents »
I connect my F5-221 tnas with network cable and wifi usb key.
My usb key is recognized by the tnas (appears in the tos interfaces list)
When I go to the Wifi tos tab, I can see the wifi networks around the tnas.
As I also have a 5Ghz wifi network, the ssid of my network appears two times but, if I choose the first or the second, the tnas always connect on the 2.4Ghz, not the 5Ghz !
If I connect to the tnas using ssh, I also can see the two ssid with 2.4Ghz and 5Ghz frequencies using iwlist wlan0 scan
Is it please possible to connect on 5Ghz ?
F5-221 TOS 6.0.217, 3 x 4TB RAID5 + 2 x 2TB TRAID
Re: Wifi Frequency
Generally speaking, there's no problem. Can't you search for the 5GHz frequency band? Or did the connection fail?
Return to “Network & Remote Access”
