Hello.
I had an issue trying to update TOS from last 5.x to 6.0beta, because system partition was too small (I had 2.9Gb, but 8Gbyte system partition is required).
I want to explain how I solved (now I am running 6 beta) without any data loss:
My system partition was only 2.6Gbyte; using ssh, i checked with "df -h"
Then, I have checked raid devices with: "cat /proc/mdstat"
/dev/md9 is a raid-1 and is the system (root) partition; raid menbers are all the 5 drives (sda2, sdb2, sdc2, sdd2, sde2)
/dev/md8 is a raid-1 and is the swap partition; raid menbers are all the 5 drives (sda3, sdb3, sdc3, sdd3, sde3)
/dev/md0 is a raid-5 and is the data partition (/dev/sda4, /dev/sdb4, /dev/sdc4, /dev/sdd4, /dev/sde4)
With fdisk -l I see that only /dev/sda has the second partition (sda2) of 7.6 Gbyte; the other 4 drives have a smaller partition.
But all the 5 drives have the 4th partition starting from the same sector, so there is free space on the 4 drives (sdb -- sde).
What I have done ?
For every drive, starting from sdb through sde:
mdadm --fail /dev/md8 /dev/sdb3
mdadm --remove /dev/md8 /dev/sdb3
mdadm --fail /dev/md9 /dev/sdb2
mdadm --remove /dev/md9 /dev/sdb2
fdisk /dev/sdb
delete partitions 2 and 3
create again partitions 2 and 3; on second partition use the first sector available, and use the same ending sector of the sda2 partition.
create partition 3 using first and last sector available.
Insert again devices on raid units:
mdadm --add /dev/md8 /dev/sdb3
mdadm --add /dev/md9 /dev/sdb2
Wait some seconds for rebuild, and then procede with sdc/sdd/sde
A the end:
mdadm --grow /dev/md9 --size=max
resize2fs /dev/md9
now your system partition is 7.6Gbyte and you can successfully install TOS 6
Hope that can help someone.
Fabrizio
I had no data loss or similar, but you will choose to make a backup copy or not.
Problem with TOS 6 and system partition smaller than 8Gbyte
Jump to
- GENERAL
- ↳ News & Announcements
- ↳ Know More About TOS 5
- ↳ Know More About TOS 6
- ↳ Lounges
- TNAS (TerraMaster NAS)
- ↳ FAQ & User Guides
- ↳ Initialization & installation
- ↳ System Configuration
- ↳ File Service
- ↳ Networking
- ↳ Storage
- ↳ Backup & restore
- ↳ Hardware
- ↳ Applications
- ↳ Update Notice
- ↳ TOS
- ↳ Initialization
- ↳ System Update
- ↳ Privileges
- ↳ Network & Remote Access
- ↳ File Services
- ↳ Storage
- ↳ Compatibility
- ↳ System Resources
- ↳ Security
- ↳ Mobile Apps and Desktop Clients
- ↳ Data Backup
- ↳ How to back up? Which one is right for me?
- ↳ TerraSync
- ↳ Centralized Backup
- ↳ Duple Backup
- ↳ USB Copy
- ↳ Snapshot
- ↳ CloudSync
- ↳ TFM Backup
- ↳ TFSS
- ↳ Rsync
- ↳ Time Machine
- ↳ Multimedia
- ↳ DLNA/Multimedia Services
- ↳ Multimedia Server
- ↳ Terra Photos
- ↳ Plex
- ↳ Emby
- ↳ Jellyfin
- ↳ Virtualization
- ↳ Docker
- ↳ Virtual Machines
- ↳ Other Applications
- ↳ iSCSI Target
- ↳ Surveillance Manager
- ↳ VPN Server
- ↳ Download
- ↳ Web Server/PHP/MySQL/MariaDB
- ↳ Terra Search
- ↳ Others
- ↳ New Features Wanted
- ↳ Developer Discussion Room
- ↳ Hardware, Power and Accessories
- TDAS (TerraMaster DAS)
- ↳ Thunderbolt 3 Series
- ↳ USB Series
- ↳ USB Series
