I'm new to NAS tech...going to love it if it works!
Setting up my new F3-423. Creating shared folders. I created a few, they worked. I saw them on network MACs and logons.
I then discovered how limited TOS_5 is with mapping folders to different apps, so I had to delete my folder structure to create new shared folders in the root directory the TOS recognizes.
Issue: I can see the new shared folders in the control panel and file manager, but none of the computers on the network see these new folders.
Troubleshooting:
1.) I checked user permissions and folder permissions...all set to read/write
2.) I went to advance settings to reset shared folders
3.) I rebooted the NAS multiple times
4.) I deleted and redid the folders using the default admin account, not my user account w/ admin permissions.
5.) I have read every FAQ I could find...
Tried to open a tech support ticket, but e-mail won't let me send the required downloaded file as its too big.
Thanks for any help w/ getting my shared folders visible,
David
New Shared Folders don't show on networked MACs
Re: New Shared Folders don't show on networked MACs
If you are inquiring about technical support email, please continue to communicate with them. Regarding the files you want to transfer, you can use sharing tools such as cloud disk sharing or WeTransfer.
Don’t understand your response.
I’m trying to get the TOS shared folders to be seen on other Mac computers that are on my network. This post is not about an issue of transferring files. My question on this post is about the shared folders you create in the TOS.
David
David
Sounds like it is a permissions issue. Different users on other computers not having permissions on NAS? Network machines being blocked by file transfer permissions on NAS?
OMG, Gremlin you gave me the guidance I needed!!!
I set them all up using "no limit"... and they did not show as shared on my network.
You mentioned permissions as the issue so I tried setting permissions "by user" and then selected ALL the users. I NOW HAVE SHARED FOLDERS!!!!
Thank you all!
David
Thank you all!
David
We will advise the relevant project team to confirm this.
After verification, it was found that if you set "Unrestricted" for the first time, you may not be able to access through SMB, and the problem can be solved when you reset the permission once.
This will be fixed in a future version.
- DigitalAnalog
I can confirm I've also experienced this issue with TOS 5.1 on a F4-423.
