Stuck on loading screen after TOS 6 upgrade
Kennic556
Post by Kennic556 »
I have a F2-423 and I upgraded to the TOS 6 beta, after the upgrade and the NAS rebooted when you try to login the Loading.... Please Wait screen come up. It been that way for 24 hours and nothing on my drive is accessible. How can I fix this?
Re: Stuck on loading screen after TOS 6 upgrade
Hi, may I ask if you remember the TOS version before the update? Have you confirmed that the TOS version meets the requirements of TOS 5.123 and above before the update?
Please observe if the hard drive light is constantly flashing? If it keeps flashing, it is possible that the file system is performing detection, which can be seen on devices with large amounts of data. Please continue to wait.
If you believe that the issue is caused by this update, you can reinstall TOS.1.123 and then consider whether to continue updating TOS6 beta according to your needs.
Return to “System Update”
