nas been on over the night in hopes it would fix itself. but it just keeps beeping after update and i cannot reach web portal.
and all data on the drives are lost.
The TOS 6 Beta Is Now Available for Public Testing
- great0dane
Re: The TOS 6 Beta Is Now Available for Public Testing
Hello, I am wondering where all the Hyper Cache settings went? My preferred cache method was write-through. I do not want to write files to the SSD cache until they are called. When a file is opened it should be stored on SSD cache, files that are accessed most are then cached for read often. I also notice the option to jump the cache for large file transfers is now missing.
The array may be damaged. You can try to boot with one less disk inserted.
Please pay attention to item 9 of the notes on updating TOS6 in this post.
latest version of tos 5 i do not remeber the exact version but i followed the update guide you posted and i was higher than the version you outlined.
5.1.123 is the latest version of 5.1. Did you upgrade from this version? If you upgrade to a version lower than 5.1.123, system exceptions will occur after the upgrade.
no i had a much higher verion. i was on latest version of tos 5. t6-423 32gb ram fully upgraded nas.
tried booting with internal terramaster usb drive. did not work eaither.
