Using TOS 5.1.123
Is it possible to make usbsharex Read Only for a certain user?
I see from Control Panel -> Storage Manager -> USB Device, I can set each user Allow or Deny. That works great but it grants full read/write access with Allow.
From File Manager -> usbsharex -> permissions, it appears that you can set each user to deny, read/write or read only but when I change any setting and confirm it goes right back to read/write.
Make usbshare Read Only
Re: Make usbshare Read Only
Thanks for sharing, we need to verify if this problem exists.
- apexfiddler
Just checking in to see if you were able to verify if this problem exists on your end.
