Odd behaviour setting up Bond (LAGG)
I recently had to make changes to my network after ISP replaced router having first hard-reset it along with all my DHCP settings and no backup config :evil: . With new router I had to make some choices, bearing in mind I had numerous devices already pointing to prreviously assigned addresses. I opted for fixed IP addresses for NAS == 2 x NAS units each with 2 x LAN and a Bond [Balance-alb].
Having set the LAN addresses I created the Fixed IP Bond, following the "suggested" (and logical) fixed LAN address of LAN1 for the BOND. When I susequently looked at TNAS-PC I noticed something odd. The BOND was using the LAN1 address but had picked up the LAN2 MAC address., (Note the MAC address is not shown in the Fixed IP setting on NAS for BOND IP.)
I ran 'ifconfig' on both NAS to confirm what I was seeing (LAN1 = eth0 and LAN2 = eth1)
[What you cannot see in the attachment are the details shown in TNAS-PC changing as they switch from LAN to BOND display and back again.]
I rearranged the IP assignment on the LAN adapters and this appears to have sorted things out into a more 'sane' (?) arrangement, but with the BOND showing as allocated to LAN2 in both cases.
Is there any logic in how interfaces are allocated to LAGG/Bond? Does Interface Servicing order have any effect?
Re: Odd behaviour setting up Bond (LAGG)
We have to verify the issues in our lab only after the new year holiday. will come back to you as soon as we make it.
Thank you.
I'll add this. Later screen shot shows "correct behaviour" in TNAS-PC. However, GUI Control panel - Overview still shows the "reversed" MAC adddress for the Bond interface.
Best wishes for your New Year :mrgreen:
Return to “Network & Remote Access”
