TOS 5.1.123 (X86) is Released for Update
brunix86
Italy
Re: TOS 5.1.123 (X86) is Released for Update
Post by brunix86 »
Juan87 wrote: 29 Jan 2024, 23:03 When updating to version 5.1.123 I have noticed that the USB drives have been listed as mnt/@usb/usbshareN/xxxxxx
instead of the previous name volumeX/@usb/usbshareN/xxxxxx.
Terrible consequences: Applications that referenced files located on USB devices can no longer access them. It is necessary to rename the libraries that contain them in those applications. For example Plex.
We hope that this change is definitive and does not return to the previous nomenclature.
(translated with google)
Hi, I have the same problem but Plex cannot see "mnt" folder and can see only empty USB device, as you can see:
Plex-USB
Plex-USB
So now I cannot use USB device as multimedia source for Plex.
Plex folder explorer
My NAS Environment
  • TNAS F4-423
  • TOS 5.1.123-00529 (8GB System Partition)
  • 2x RAM Terramaster 4GB DDR4 2133 MHZ
brunix86
Italy
Post by brunix86 »
Hi, I changed manually the path, replacing "Volume1" with "mnt" and it works.
But I'd like to know if there will be further changes related to USB paths.
My NAS Environment
  • TNAS F4-423
Tricky
Post by Tricky »
TMeric wrote: 29 Jan 2024, 22:12
Tricky wrote: 29 Jan 2024, 20:52
Tricky wrote: 25 Jan 2024, 22:42 No problems here, 103 to 123.
Just discovered that media server won't stay active, why does this happen on so many of the updates? One time it will be OK, and the next update will have problems!
Thanks for your feedback, we'll verify it in the lab.
My mistake when I updated this machine i didn't notice at first that it had knocked out the port info, not sure why it did this on this machine and not my other.
Mind you I have been having trouble with this one as it seems to totally disappear from the network if there is a power outage, or it turned off and nothing will get it back bar re initialising, (It's kept for testing with very little stored) it's happened three times now with the last few updates?
JakeF150
Post by JakeF150 »
Same here with USB Backup, previous backup definition stated drive offline.
Simply re-created backup definition and removed the previous and all is fine.
Model: F2-220, Memory: 4gb, Drives: 2x3tb raid 0, Backup: 5tb usb, Version: 5.1.123
Ortof
Post by Ortof »
I upgraded from version 5.1.95 to 5.1.123 without any problems.
Marshal
Post by Marshal »
Tricky wrote: 30 Jan 2024, 04:36
topo01
Germany
Post by topo01 »
Just updated 5.1.103 -> 5.1.123
Looks good so far. But again had to do it manually as the system did not "see" any update available online.
F2-220, TOS 5.1.123 (8GB system partition), Docker 2.0.16 (Nextcloud, AdGuard Home), Terra Photos 2.0.13
topo01
Germany
Post by topo01 »
In 5.1.123 I still see the issue with date and time that the system shows NaN:NaN:NaN if format dd.mm.yyyy is selected (standard for my region).
Strangely this only happens on my iPad. Everything seams fine on other devices (Chrome on windows and Opera on Android). And yes, I did fully clear cache of Safari browser.
bidmead
Post by bidmead »
No mention here of a TNAS PC update for Linux. Has this been discontinued?
Chris
RoyRogers
Post by RoyRogers »
Updated manually 5.1.67 -> 5.1.123 no issues
Did fix a 'no internet connection' error though it might have been the reboot (I'm using SMB3 Multichannel)
qBittorent still won't start though
