Expanding storage on RAID 1 D2-310
bbdcl
Post by bbdcl »
I wanted to check the following in relation to usage of the D2-310.
I currently have 2x 2TB drives in a RAID 1 setup connected on USB to a Linux single board computer (odroid).
If I want to upgrade my storage capacity can I take out a 2TB drive and replace with a bigger one e.g. 4TB? Will the RAID rebuild on the 4TB?
If I then replace the remaining 2TB drive with another 4TB drive presumably that will then rebuild on to that too? Will the final RAID drive(s) end up with just a 2TB partition though?
Further questions...
Does the fresh drive get automatically formatted and the rebuild happen automatically? How do I know it's happening and when it's finished?
Is there any way of checking the health status of the drives in the enclosure?
Thank you.
Re: Expanding storage on RAID 1 D2-310
Hi bbdcl,
As D2-310 adopts a hardware RAID controller, the RAID capacity online expansion does not work there. So you can't get bigger capacity by replacing a hard drive with bigger size after the raid been set.
bbdcl
Post by bbdcl »
Ok, thank you. So, to confirm I would need to put in 2x new 4TB drives , create an empty RAID and then copy files from old 2TB drive to the new RAID?
Think I saw in another post that there is no way to check the drive health of the drives in the enclosure. Is that right?
Yeah, you need to create a new raid with new drive.
Here are some tools to check the drive health, hopefully one of them is helpful for you.
https://www.lifewire.com/free-hard-driv ... ms-2626183
bbdcl
Post by bbdcl »
Thank you
Return to “USB Series”
