TNAS Mobile 3.2.31
lenny
TNAS Mobile 3.2.31
Post by lenny »
My mobile app has recently been updated to version 3.2.31.
I now cannot connect to my server.
The server is running version 4.2.41-2203011629.
The server is an F4-210 and I understand I cannot update the software to a higher version such as V5.
I have tried adding server by IP and port number and by name etc.
Is access now not possible due to the F4-210 not being supported for V5?
In which case it's time to consider dumping the F4-210 for something else even though it's not that old.
Many Thanks,
Len
TMtina
Re: TNAS Mobile 3.2.31
Post by TMtina »
You need to use TNAS mobile instead of TNAS mobile 3. The following is the download link:
Android: https://download2.terra-master.com/TNASmobile_Andro Id_2.4.20.apk
iOS: https://apps.apple.com/app/tnas-mobile/id1244630532
sprietof
Post by sprietof »
Hello. I'm trying to install TNAS Mobile 3 from Google Play in my Samsung Galaxy A13 5G, but I get the following error: Your device is not compatible with this version. What is the problem? How can I install this App on my mobile.
lenny
Post by lenny »
I downloaded from here in the end,
https://support.terra-master.com/downlo ... uct=F4-210
Then mobile applications and used the QR code to download application.
Hopefully Android updates wont update it to v3 again.
Shame that the F4-210 is not getting any further updates and feel I've wated my money as I've not had it that long.
TMtina
Post by TMtina »
{L_BUTTON_AT}sprietof
What version of Android is your phone running?
sprietof
Post by sprietof »
@TMtina
Android Version: 13
Kernel Version: 4.14.168-27210951
sprietof
Post by sprietof »
Any solution to this issue?
I am sorry to tell you that the F4-210 does not work with TNAS mobile 3.
sprietof
Post by sprietof »
Sorry, my NAS is the F2-223 model, I think it is compatible. What could be the problem why my mobile phone is not compatible with the App?
If you follow the link you posted, you have downloaded the wrong version I think. [Downloads section is separated by NAS model and then you have to find the item that matches nas model and (in this case) phone type.
Return to “Network & Remote Access”
