[ Noisedash ] Self-hostable web tool for generating ambient noises
About: https://github.com/kaythomas0/noisedash
Category:
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
Applicable TOS6: 6.0.124 or later versions
App download: https://tmnascommunity.eu/download/Noisedash
TOS4: http(s)://yournasip:port/modules/pgAdminOKM/www
TOS5 & TOS6: click on Support & Help from app description inside the App Center
About
Features
Generate and customize ambient noises and user-uploadable samples (leveraging Tone.js)
Save "noise profiles" so you can easily switch between your created soundscapes. Import and export them for easy sharing, record them for use elsewhere
Fine-tune your noises with audio processing tools like filters, LFOs, and effects
Upload and edit audio samples (e.g rain, wind, thunder) to combine with your generated noises. Add effects to them and set playback modes
Use admin tools to manage multiple users
Mobile friendly
