I've just bought an F2-223 and I'd like to know if I can install 1 Nvme disk just to install the TOS system and Terramaster applications?
The data will currently be on 2 HDDs in raid 1.
What size should the Nvme be?
Is 1 or 2 Nvme better?
Which Brand/Model ?
f2-223 recommended size for TOS install and Application on Nvme ?
- beuzbeuz78
F2-210 & D5-300C & F2-223 now
- crisisacting
Re: f2-223 recommended size for TOS install and Application on Nvme ?
This will be possible in the forthcoming TOS 6 once an .INS fresh installation option becomes available when it's fully released publicly.
viewtopic.php?f=97&t=5381
Yes, you can do this.beuzbeuz78 wrote: ↑23 Dec 2023, 18:32 Hi,
Which Brand/Model ?
You can refer to the link below to choose the appropriate NVMe
https://www.terra-master.com/global/compatibility/
- beuzbeuz78
Ok, which size do you recommanded for TOS+Application on the Nvme ? minimum/maximum ?TMeric wrote: ↑24 Dec 2023, 11:06Yes, you can do this.beuzbeuz78 wrote: ↑23 Dec 2023, 18:32 Hi,
Which Brand/Model ?
