Qbittorent Web UI Advanced Settings?
Transmission, qBittorrent, Aria 2 download applications
mikeby
Post by mikeby »
Using the Qbittorent App on a TNAS F4-423 opens a Qbittorent EB UI. There does not appear to be an Advanced section under Options like there is in a Windows client. This is where I can bind the torrent execution to a VPN client so that it stops if the VPN Client disconnects. Is there a similar setting that can be found using the WEB UI?
Return to “Download”
