Docker IPv6
Discussion about Docker
philh
Docker IPv6
Post by philh »
im currently trying to setup some services to work with IPv6.
Unfortunately it does not work and a cant find a option to enable it.
Services that run natively, like the TOS webinterface are accessable using the IPv6 ULA addr (2000:: ) though.
Is it possible to use docker services with ipv6?
Some more context: My cable provider does not offer an public ipv4 address, only some DS-Lite access.
I would like to make some services like plex accessible though and one option seems to be a port mapper.
Thanks for your answers!
Re: Docker IPv6
I don't know why you need to use Docker to achieve IPv6 connectivity. Is your TNAS model 210 series that doesn't support IPv6?
Generally speaking, if you can access a service (HTTP/HTTPS port of TOS webinterface), other services can also access it.
If I do not fully understand your question, please provide more details and description.
Return to “Docker”
