TOS 6 Insider Preview Program
Re: TOS 6 Insider Preview Program
Is a bit difficult to find the buttons for Log out, Restart and Shut Down (They are in start window). Having a text under these buttons will be more intuitive.
outkastm wrote: 03 Dec 2023, 23:02 Is a bit difficult to find the buttons for Log out, Restart and Shut Down (They are in start window). Having a text under these buttons will be more intuitive.
'Hovering' the cursor shows what they are, but that seems to be the way with "modern" systems ;) Having them duplicated on the desktop might be user friendly. It would be interesting to know which devices were "designed for" and which "tested on" prior to release. A large screen tv might be ok but a small hand held possibly not.
Yes "hovering" the cursor show the description indeed, but as my personal experince on the usage, it should have the description directly visible.
Something that Windows 11 still has it... :D .
This is only my feeling...
Image.
Hmmm.
Just realised that if you expand something like 'Control Panel' to max size, the banner with the buttons disappears anyway. And you can't see the buttons on rhs either.
Pisti7204
Post by Pisti7204 »
I just want to let you know that the update to version 6.0.124 was successful. I did it with remote access, everything went fine.
I would like to note that when the update started, there was no feedback (pop-up), but the NAS suddenly restarted. Something to indicate that the update is in progress would be nice.
mnewland
Post by mnewland »
@Pisti7204 when do you get the email for 6.0.124 I'm still on 6.0.108.
My TNAS
  • Device = T6-423
  • RAM = 32gb official Terramaster ram
  • Disks = 3 x Seagate IronWolf ST400VN006 4TB
  • TOS = 6.0.217
  • BIOS = 5.19
  • Mobile App = 3.2.31
mnewland wrote: 05 Dec 2023, 20:10 @Pisti7204 when do you get the email for 6.0.124 I'm still on 6.0.108.
Just got notification on-line when I logged into NAS gui.
TMwuu
Post by TMwuu »
{L_BUTTON_AT}Gremlin
Please go to the system module in the control panel to check for updates.
Update from 6.0.108 to 6.0.124 went fine.
The auto reboot after upgrade is usefull, but will be good to have a note in the Notes section that after the upgrade process the NAS will reboot itself.
Gremlin wrote: 05 Dec 2023, 20:15
I wasn't the one asking, I was telling :D
