F2-210 2 x 4Tb Cannot Reinitialize Hard Drives
TosBob
Post by TosBob »
This is a new unit i just got. Instalation went fair. Even got three movies up there, But then I realized i screwed up on the RAID. I decided to go thru the initialization process again. The process stopped and jumped to end just before the RAID initilazion portion began.
Wondering how to clear HD's and get new RAID settings?
I would like to reset NAS back to out of box status?
Thank you!
TosBob
Re: F2-210 2 x 4Tb Cannot Reinitialize Hard Drives
You can achieve your goals in the TOS Control Panel and you dont need to reinstall TOS.
Go to Control Panel - Volumes, delete volumes.
Go to Control Panel - Storage Pools, Delete Storage Pools (RAID).
Then recreate a new storage pool (RAID) and volume.
TosBob
Post by TosBob »
Yes that worked.
Thank you!
Return to “Initialization”
