I have a Samsung Galaxy S23 running Android 14. The TNAS app repeatedly pushes an update notice (New version, 3.2.31) as attached.
When I select "Update", the dialog disappears, but nothing else happens, and the dialog reappears a little while after - again, with no effect.
I have enabled "Install unknown apps" for the TNAS app, but it is not possible to enable notifications (the app does not appear in the "notifications" list, and the "Allow notifications" option is greyed out in the app settings).
The app updates fine on a borrowed Galaxy S10, so this seems to be a particular problem with the device and Android combination.
Thanks.
TNAS Update on Android 14 Samsung Galaxy S23
- Attachments
- Screenshot_20231106_143410_TNAS mobile 3 (Small).jpg (22.85 KiB) Viewed 1294 times
Re: TNAS Update on Android 14 Samsung Galaxy S23
Thank you for your feedback, we will verify it. Which version of the application is you currently using? If you want to update the app, here is the download link for version 3.2.31: https://download2.terra-master.com/TNAS ... 3.2.31.apk
I think it was 3.2.25, but I have now successfully updated it using the APK that you provided.
Thank you
Thank you
I have gone from Samsung S21 to S23 transferring data and applications and TNAS works perfectly for me, just like on the previous phone. The version of TNAS used is 3.2.25
I have the same problem (Samsung S22 Ultra, German localization) with TNAS Mobile 3.2.25.
When checking the Playstore, it says that the current version (so 3.2.25) is the newest one and has been updated in the store on 12th September.
