Sonarr, sabnzbd and radarr setup on TNAS
KGT
Post by KGT »
Hi i was wondering how to get sonarr, sabnzbd and radarr all setup and configured on TNAS, is there a walkthrough anywhere i can follow? or if someone on here could help me out, TIA
KGT.
Edited: finally, found solutions here.
Re: Sonarr, sabnzbd and radarr setup on TNAS
For the apps you mentioned, they have not been integrated to our TOS system. You may try with Docker to install them.
KGT
Post by KGT »
yeah i know i need to use docker but was just seeing if anyone could help me configure and set it up using docker as the only tutorials i can find are ones for synology
mrorange26
Post by mrorange26 »
Hi did you manage to get sabnzbd to work.
macmpi
Post by macmpi »
nzbget Alpine-based container is a good low-ressource alternative for sabnzb.
Works great on arm64-based F2-210
mrorange26
But how do you install it on terramaster.
macmpi
Post by macmpi »
in Docker app, set Registry to: registry.hub.docker.com
Then search for nzbget and download linuxserver/nzbget
Then in image section, select the image and do launch, and configure the various tabs according to container info:
(you may use different target directories for /config and /downloads)
(you may change timezone to yours)
mrorange26
Thanks just gonna try now,
Could you show me howto setup sabnzbd and sickbear aswell.
Many thanks
mrorange26
Ok just tried the settings when its on host the container disappears
But when its on bridge it doe not.
mrorange26
Also how do i get couchpotato to talk to nzbget so that it tells it when to download.Thanks
Return to “Others”
