I started experimenting with Docker a bit, didn't have the time so I uninstalled it. I just upgraded to TOS 5.1.79 and wanted to try getting back into Docker.
There is no Docker in my application list. There is Docker Manager, but no Docker. It was there before, not now.
Am I crazy or just not understanding this? I have found a docker image that I want to download and set up (qbittorrent with vpn)
Thanks!
No Docker?
Re: No Docker?
What is your docker version? Try to reinstall it.
Re: No Docker?
How do I reinstall it? When I search for the app, I only see "Docker Manager" - there is no "Docker" in my application list.
Re: No Docker?
I was able to find the option in the Docker Manager to find the repository and download a container.
Having problems getting it set up but I think that's on me to sort out.
Thanks!
Thanks!
