F2-221 slow file transfer speeds SMB - hpet enabled
henrychr
Post by henrychr »
System Info:
TNAS: F2-221
TOS: 5.1.79
Devices:
Windows 10
Chromebook
Issue:
After updating to TOS 5.1.X from TOS 5.0.X, SMB speeds have dropped from usual 100 mb/s and now average around 20mb/s, but have seen consistent speeds as low as 5 mb/s.
Hooking monitor up to TNAS while it's running, entire screen is a log of
timestamp hpet: lost 7161 RTC interrupts
timestamp hpet: lost 7160 RTC interrupts
Remedies mentioned in the 5.1.67 update post say to either change the boot disk order or to disable hpetm however I can't do either of these in the BIOS, the option is simply not there.
henrychr
Re: F2-221 slow file transfer speeds SMB - hpet enabled
Post by henrychr »
Forgot to mention, I upgraded from 5.0 to 5.1, encountered slow SMB speeds, then did a reset and a clean install to 5.1 and issue persists.
Do you have scheduled "power off/power on" functions entered in the control panel? We have been down this path before.
henrychr
Post by henrychr »
Shoot, I do have that.
Suggest you remove all the entries (disabling is not sufficient) and check SMB again. Please report back for my benefit if noone else's :D
henrychr
Post by henrychr »
@gremlin - disabling the schedule seemed to fix SMB, but I'll delete them next and see. Plugging the TNAS into a monitor, I can see the hpet: lost waterfall stopped soon as I turned the schedules off.
Thanks, that (disabling only) seems like a slight change from previously.
henrychr
Post by henrychr »
I did end up deleting the power schedules as well, just to be safe / I don't need them so why keep them.
It's probably a safe assumption that scheduling events, like enabling/disabling an app, would also cause hpet to turn on. I didn't have any of those but will keep in mind probably best not to set any.
I run customised scheduled event every day (find and delete files) and it has no effect. It only seems to be the power on/off schedule that has been an issue. (so far!)
TMRyan
Post by TMRyan »
{L_BUTTON_AT}henrychr
Is it convenient to contact our technical support team for remote inspection?
