Nextcloud File Size Solution
CloudSync is a cloud drive synchronization application for fast and secure data synchronization between your TNAS and cloud drives. It is a very practical and efficient one-stop cloud drive disaster recovery solution.
ahochreiter
Post by ahochreiter »
Myself, as many others encountered this problem while using the terramaster nextcloud app-package:
Server replied "413 Request Entity Too Large"
Yet, no solution was ever provided.
To add insult to injury, those topics even got locked up so further discussion was surpressed.
The main problem at hand is the nginx server running on port 8181, having an itsy bitsy small allowed upload size of 100 MB.
All you need to do is to change that and restart the service.
1. Connect to the NAS via SSH. (User = your nas user, SSH Port = open the nas's webinterface, then go to Systemsettings > Terminal & SNMP > Telnet / SSH and make sure SSH is enabled and you asigned a port number)
2. Open nginx's config
sudo vi /etc/nginx/nginx-http.conf
3. Search for the line containing
client_max_body_size 100M;
(is probably line around line 4 or 5)
4. Replace the 100 MB with whatever you want eg 10GB
client_max_body_size 10G;
5. Save and close the file
6. Restart the nginx service
sudo service nginx restart
The change will take effect immediately. You can re-attempt to sync files from your nextcloud client now.
Have fun!
zelmajackson
Re: Nextcloud File Size Solution
Post by zelmajackson »
Thanks for sharing this effective solution. It works for me
Return to “CloudSync”
