Internet is not working when VPN is connected
An application set your TNAS as a VPN server
XFNeo
Post by XFNeo »
Hi, I have 2 problems with OpenVPN server:
1) I have enabled "Allow clients to access the local area network where the server is located" on the latest version 2.0.49 and I cant connect to any hosts in TNAS local network e,g, TOS UI via local address https://192.168.1.10:5443 does not work, but it works via https://172.10.11.1:5443
2) After update TOS to 5.1.67 and update Docker Manager to 1.2.6, my OpenVPN does not work properly: when I connected to it internet is not working at all, but I can open TOS UI using IP 172.10.11.1. I have tried on PC, mobile and laptop.
ping 8.8.8.8 -t
Exchange of packets from 8.8.8.8 to 32 bytes of data:
Reply from 8.8.8.8: number of bytes=32 time=49ms TTL=60
Reply from 8.8.8.8: number of bytes=32 time=65ms TTL=60
#####Connecting to VPN#####
PING: transmission failed. General failure.
#####VPN is connected#####
Timed out request.
Timed out request.
Timed out request.
Timed out request.
Timed out request.
Timed out request.
Timed out request.
Timed out request.
#####VPN is disconnected#####
TNAS:
# route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.1     0.0.0.0         UG    0      0        0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 eth1
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 veth35f58bf
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 vethbacadd4
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 veth802eeac
169.254.0.0     0.0.0.0         255.255.0.0     U     0      0        0 veth659055e
172.10.11.0     172.10.11.2     255.255.255.0   UG    0      0        0 tun0
172.10.11.2     0.0.0.0         255.255.255.255 UH    0      0        0 tun0
172.17.0.0      0.0.0.0         255.255.0.0     U     0      0        0 docker0
172.19.0.0      0.0.0.0         255.255.0.0     U     0      0        0 br-8b137c1fd954
172.20.0.0      0.0.0.0         255.255.0.0     U     0      0        0 br-d295c66d1d24
172.21.0.0      0.0.0.0         255.255.0.0     U     0      0        0 br-12a9da5f24a5
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
PC with connected VPN:
#route print
IPv4 route table
Active routes:
Network address Network mask Gateway address Interface Metrics
          0.0.0.0          0.0.0.0     192.168.31.1   192.168.31.122     25
          0.0.0.0        128.0.0.0      172.10.11.5      172.10.11.6    257
  119.229.119.120  255.255.255.255     192.168.31.1   192.168.31.122    281
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
        128.0.0.0        128.0.0.0      172.10.11.5      172.10.11.6    257
      172.10.11.0    255.255.255.0      172.10.11.5      172.10.11.6    257
      172.10.11.4  255.255.255.252         On-link       172.10.11.6    257
      172.10.11.6  255.255.255.255         On-link       172.10.11.6    257
      172.10.11.7  255.255.255.255         On-link       172.10.11.6    257
     192.168.31.0    255.255.255.0         On-link    192.168.31.122    281
   192.168.31.122  255.255.255.255         On-link    192.168.31.122    281
   192.168.31.255  255.255.255.255         On-link    192.168.31.122    281
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link       172.10.11.6    257
        224.0.0.0        240.0.0.0         On-link    192.168.31.122    281
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
  255.255.255.255  255.255.255.255         On-link       172.10.11.6    257
  255.255.255.255  255.255.255.255         On-link    192.168.31.122    281
Regular routes:
   Absent
#tracert 8.8.8.8
Trace route to dns.google [8.8.8.8]
with a maximum number of hops of 30:
   1 45 ms 45 ms 45 ms 172.10.11.1
   2 * * * Request timeout exceeded.
   3 * * * Request timeout exceeded.
   4 * * * Request timeout exceeded.
   5 * * * Request timeout exceeded.
   30 * * * Request timeout exceeded.
Tracing is complete.
I deleted VPN Server, rebooted the NAS and installed it again. It did not help.
The same issue.
But veth* interfaces are disappeared.
# route -n
XFNeo
Re: Internet is not working when VPN is connected
Post by XFNeo »
I have found root cause of broken VPN - it is DDOS protection. When I disable it, internet started working with VPN.
But the most interesting thing that FORWARD chain policy changed from DROP to ACCEPT when I disabled DDoS protection.
Chain FORWARD (policy DROP)
Chain FORWARD (policy ACCEPT)
Before:
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
DOS_PROTECT  all  --  anywhere             anywhere
DOCKER-USER  all  --  anywhere             anywhere
DOCKER-ISOLATION-STAGE-1  all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate RELATED,ESTABLISHED
DOCKER     all  --  anywhere             anywhere
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (3 references)
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2  all  --  anywhere             anywhere
RETURN     all  --  anywhere             anywhere
Chain DOCKER-ISOLATION-STAGE-2 (3 references)
DROP       all  --  anywhere             anywhere
Chain DOCKER-USER (1 references)
Chain DOS_PROTECT (1 references)
RETURN     icmp --  anywhere             anywhere             icmp echo-request limit: avg 1/sec burst 5
DROP       icmp --  anywhere             anywhere             icmp echo-request
RETURN     tcp  --  anywhere             anywhere             tcp flags:FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5
DROP       tcp  --  anywhere             anywhere             tcp flags:FIN,SYN,RST,ACK/RST
RETURN     tcp  --  anywhere             anywhere             tcp flags:FIN,SYN,RST,ACK/SYN limit: avg 10000/sec burst 100
DROP       tcp  --  anywhere             anywhere             tcp flags:FIN,SYN,RST,ACK/SYN
After:
XFNeo
Post by XFNeo »
Any updates?
XFNeo
Post by XFNeo »
On every TNAS reboot drop policy returned and I need to switch on\off DDoS protection to update iptables!
from Chain FORWARD (policy DROP) to Chain FORWARD (policy ACCEPT)
May I ask if your VPN is now able to connect normally?
Do you mean that the switch of the DDOS option may affect Firewall?
XFNeo
Post by XFNeo »
TMzethar wrote: 17 Oct 2023, 20:12 May I ask if your VPN is now able to connect normally?
Yes, now it works normaly with "Chain FORWARD (policy ACCEPT)" rule in iptables.
After reboot TNAS in iptables I see Chain FORWARD (policy DROP)
I goes to DDoS protection in TNAS UI and turns it on, it adds own rules and also change "Chain FORWARD (policy DROP)" to "Chain FORWARD (policy ACCEPT)"
I have no idea who set "Chain FORWARD (policy DROP)"
Return to “VPN Server”
