TOS 6 is Getting Closer to You...
Re: TOS 6 is getting closer to you...
Oh! you tease!
gaz2k1uk
Post by gaz2k1uk »
Didn't you just release TOS5?
Setup:
System: F2-422
OS: TOS 5.1.123
HD: x2 6GB IronWolf 6TB (RAID 0)
Notes: 8GB System Partition!
Backup:
USB COPY: Seagate 8GB External Expansion HDD
SquarePeg
Wales
Post by SquarePeg »
Is it going to be easy to move to or are there going to be the same issues as with TOS5?
Econokiller
Post by Econokiller »
When are they going to release one for The ARM machines F4-210
ostaporomo
Finland
Re: TOS 6 is Getting Closer to You...
Post by ostaporomo »
Thanks for good news!
When is the public beta release expected?
TNAS F2-223
TOS 5.1.79-00214
2x RAM Samsung 16GB DDR4 2133 MHZ
2x HDD Segate IronWolf ST4000VN008 4TB [RAID1]
DAS D4-300
2x HDD Seagate SkyHawk ST3000VX010  [RAID1]
2x HDD Toshiba DT01 DT01ACA300-3TB
musman
Post by musman »
Apple, Inc. may be unhappy with you for borrowing the version=kitty cat theme😀
yotatoy
Post by yotatoy »
The real win for TOS 6 would be a seamless update process and installer that has ability to resize system partition. Way to much headache to go from 5.0 to 5.1 with the 2GB to 8GB change.
crisisacting
Post by crisisacting »
Like other recent TOS releases, this will use the current LTS build of the Linux kernel, correct? TOS 6 should be based off Linux LTS kernel 6.1.×?
gaz2k1uk wrote: 12 Sep 2023, 20:27 Didn't you just release TOS5?
The first insider builds were made available in late 2021 & 5.1 betas came out at the end of 2022, even TOS 4.2 builds started in late 2020, so they essentially have releases in the last quarter of the year for new major builds … it's become their unofficial release timeframe.
SquarePeg wrote: 13 Sep 2023, 01:30 Is it going to be easy to move to or are there going to be the same issues as with TOS5?
The newer 8 GB system partition is likely a prerequisite to upgrade, so hopefully a verification script/step is added for in-place updates through an existing TOS setup to prevent 2 GB system partition setups from proceeding; 5.1.× (which requires the larger system partition) is probably the minimum requirement to upgrade.
The initboot/install wizard really could benefit by adding the ability to secure erase a drive or multiple drives without having to SSH onto the uninitialized NAS for fresh/clean installations.
musman wrote: 15 Sep 2023, 04:08 Apple, Inc. may be unhappy with you for borrowing the version=kitty cat theme
Apple dropped Mac OS X feline codenames/branding almost a decade ago in late 2013 with the release of Mavericks (10.9) …
To update to TOS 6, your TNAS needs to meet minimum requirements, or your update will be stopped.
