TNAS mobile 3 ver.3.2.24 crashes
- ostaporomo
Hello! Today the application has been updated via Googleplay to version 3.2.24. Now the application regularly crashes immediately after launch. Clearing cache and data didn't help. My phone is Google pixel 7, android firmware version 14 latest beta.
TNAS F2-223
TOS 5.1.79-00214
2x RAM Samsung 16GB DDR4 2133 MHZ
2x HDD Segate IronWolf ST4000VN008 4TB [RAID1]
DAS D4-300
2x HDD Seagate SkyHawk ST3000VX010 [RAID1]
2x HDD Toshiba DT01 DT01ACA300-3TB
TOS 5.1.79-00214
DAS D4-300
Re: TNAS mobile 3 ver.3.2.24 crashes
Hello, please uninstall your app and reinstall it again. And can you provide screenshots or screen recordings of related issues? This helps us resolve issues faster.
- ostaporomo
Deleted the app, rebooted the phone, installed the app from Google play. The application starts, but after accepting the license agreement, the application constantly crashes. Please tell me which screenshots I need to provide? Thanks for the help!
- Attachments
- Screenshot_20230906-162525.png (19.22 KiB) Viewed 1466 times
- Screenshot_20230906-162343.png (5.67 KiB) Viewed 1466 times
- Screenshot_20230906-162133.png (17.75 KiB) Viewed 1466 times
TNAS F2-223
TOS 5.1.79-00214
DAS D4-300
TOS 5.1.79-00214
DAS D4-300
Thank you for your cooperation! If you're using a pre-3.2.24 app, it won't crash, right? This may be related to the instability of the latest beta version of Android 14. We will resolve this issue and update the app as soon as possible. You can temporarily use version 3.2.22: http://47.90.0.247:9229/down/dAYmsBe8VZIr.apk
- ostaporomo
Hello! Android 14 Beta 5.3 UPB5.230623.009 was released tonight. Further, within a month, the release of Android 14 is expected. On it, version 3.2.24 of the application also crashes. Application version 3.2.22 does not crash, but has already known bugs. Also, it is unpleasant that on version 3.2.22 a window constantly pops up with a message about the availability of an update to version 3.2.24. But anyway, thanks a lot for your help.
TNAS F2-223
TOS 5.1.79-00214
DAS D4-300
TOS 5.1.79-00214
DAS D4-300
- andrewfarquhar
Just to confirm that I have the same issue on Pixel 6 Pro on Android 14
Same, just hangs for me
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
TNAS F5-221
1X WD 4TB USB
{L_BUTTON_AT}V8Triker
{L_BUTTON_AT}TMtina
That got me the option that it could not find my NAS.
Tried manually entering, but failed to connect.
Does it only work with TOS 5?
TNAS F5-221
1X WD 4TB USB
TNAS F5-221
1X WD 4TB USB
Yes, if you want to use the latest TNAS mobile 3.2.24, your TOS version must be no lower than 5.1.67; if you don’t want to upgrade your TOS system, you can use the 2.4.20 version of the application: https:// download2.terra-master.com/TNASmobile_Android_2.4.20.apk
