Emby updating to beta
So I have tried using the App Store emby and it shows it needs an update. I have also downloaded the image from emby but still wants you to use beta. The only way I could keep from getting the update notification on TOS5 is to use the latest beta from emby. Not sure if its me or a bug.
Re: Emby updating to beta
I have the same issue, also when trying to install the latest Emby package, it takes about 30 minutes. Doing the same thing on TOS4 though takes seconds.
It’s so annoying. The beta has to many updates the should just fix the issue with the Emby in the App Store.
