I had Hyper Cache setup OK on a 1 TB NVMe Drive (NVMe_sdza) but then shutdown via long power button press and then the Volume was corrupted. Since I was unable to recover the Volume, I deleted it and created a new Volume; was setting the F4-423 up, so no real data lost.
I now get an error with the Hyper Cache and cannot delete the old one and create a new one.
The pop-up states I need to stop all applications and stop operations on the Volume.
What are the commands to do this via SSH command line?
See attached for the error and pop-up I get.
Hyper Cache - Cannot Delete after a new Volume is setup
F4-423 - 2 x12TB & 1x14TB & 1x16TB - BTRFS TRAID
Re: Hyper Cache - Cannot Delete after a new Volume is setup
We can't accurately determine the exact situation based on these descriptions, so you can contact our technical support team via email.fcs001fcs wrote: ↑09 Aug 2023, 18:46 I had Hyper Cache setup OK on a 1 TB NVMe Drive (NVMe_sdza) but then shutdown via long power button press and then the Volume was corrupted. Since I was unable to recover the Volume, I deleted it and created a new Volume; was setting the F4-423 up, so no real data lost.
Over come by events. I factory reset the NAS and now I am installing from scratch.
Thanks.
Thanks.
