Looking at buying the F5-221, if I opt for 16tb drives in single disk configuration (just using the F5 as a NAS/plex server), do I need to initialise the disk first or can I put an existing drive in without losing data?
F5-221/single disk/16TB
Re: F5-221/single disk/16TB
You will need to initialize the disk. The operating system is loaded on to the disk (system partition) as well as the boot/init partition and a swap partition. NAS is always set to boot from a hard drive. If one drive "goes missing" (assuming multiple drives eventually) the NAS should always boot to the current OS version.
Ok Thankyou. So it doesn’t store the OS internally like a synology?
Actually, I'm not sure Synology does what you think. But, never used one. I found this just to get my bearings:
https://www.reddit.com/r/synology/comme ... oted_from/
This is essentially same way TNAS operates.
Synology do have pretty good documentation and I use it a lot to check out things for my TNAS. (Which I view, very much, as a synology clone)
