[ Grocy ] Groceries & household management solution
About: https://grocy.info/
Category:
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
App download: https://tmnascommunity.eu/download/Grocy
Required packages:
apache24
PHP81_okm
TOS4: http(s)://yournasip:port/modules/Grocy/www
TOS5: click on Support & Help from app description inside the App Center
About
Automate & optimize your shopping list
Define minimum stock amounts of your loved products and never think about "do I need noodles or are there enough at home?".
Group products by assortments to optimize your way in the supermarket - never jump from one end to the other again and again.
Recipes with intelligence
Maintain your recipes and see at a glance whether everything you need is in stock at home. Of course, everything that is not available can also be automatically added to the shopping list.
Manage your household equipment/devices
Keep all the instruction manuals and important information about your devices in one place to have them at hand when needed.
...and much more, check the demo https://en.demo.grocy.info/
