I'm using the DDNS server with DuckDNS.
I have multiples (2) domains with DuckDNS and I've been able to automatically update the DuckDns IP with the information token and password etc. But only for one domain... I'd like to know if it's possible to update more domains ?
I'm running a TM F5-221 on the version 4.2.32 (2203011626)
Remote access with multiple DuckDNS account
Re: Remote access with multiple DuckDNS account
The TOS version you are currently using only supports updating one DDNS at the same time.
If you need to set multiple:
1. You can consider setting it on the router
2. You may consider backing up data and installing TOS5 which can support multiple DDNS updates at the same time.(After you backup the data, you still need to connect the hard disk to the PC to delete the partitions. In order to have a new partition table that can meet TOS5.)
3. You can consider a domain name management website that can assist in updating multiple domain names at the same time, such as dnsomatic.
Thanks, my next move will probably update to TOS5 when I got some spare time !TMzethar wrote: ↑29 Jun 2023, 11:58 The TOS version you are currently using only supports updating one DDNS at the same time.
{L_BUTTON_AT}ekinoxben
