[NCDU] NCurses Disk Usage (CLI)
About: https://dev.yorhel.nl/ncdu/man
Category:
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.33 or later versions
App download: https://tmnascommunity.eu/download/ncdu
TOS4: http(s)://yournasip:port/modules/ncdu/www
TOS5: click on Support & Help from app description inside the App Center
DESCRIPTION
ncdu (NCurses Disk Usage) is a curses-based version of the well-known 'du', and provides a fast way to see what directories are using your disk space.
