TOS 5.1.37 (X86) is Released for Update
jgea
Re: TOS 5.1.37 (X86) is Released for update
Post by jgea »
Interesting info.
I still think giving the option to install inside an drive specified by user could be a good option, there are even SSD M.2 mounted in a USB case that could be used, so as an option I think it’s not bad.
But I get your point towards simple USB drives. :)
portainernoob
Post by portainernoob »
I am having issues with this update not connecting to trackers in qbittorrent docker as well as my plex server disappearing. I have tried to reinstall docker and portainer again and delete all files but I still get the connection error for trackers. Please help!
crisisacting
Post by crisisacting »
jgea wrote: 20 Jun 2023, 14:43 Interesting info.
Unfortunately, the short cable, drive used & its enclosure do add additional points of failure to the device, as well as added power draw as well as heat (if mounted internally; not much of an issue if external) into an already compact NAS enclosure.
They could definitely consider allowing it as an option for those ready and willing to forgo support.
thierrys73
Post by thierrys73 »
Hello
Can we insert a single disk in my terramaster T6-423 for make backups by creating a volume 2 before to shave the system to get put 8 giga 2 partition systeme
so I can reinsert the backup disk after the migration to 8 gigabytes to recover my data
thank you
{L_BUTTON_AT}thierrys73
I don't think so. Your 'backup' volume will automatically be configured with the 2 GB system partition which is a raid-1 mirror. When reinstalled as per your suggestion that raid will be degraded (even if it boots)
thierrys73
{L_BUTTON_AT}Gremlin
thanks for answers
even i built my raid with 5 disk in factory mode et when all is ok i plug my single disc for recover my datas
myrix
Post by myrix »
how can i recovery my without losing it after i broke my system (from .33 to .37)?
I tried SSH and FTP but no access.
My HDDS are WDC WD40EFAX-68J in RAID 5 (yeah i know SMR).
Regards
(in german)
(in german)
MDvP
Post by MDvP »
{L_BUTTON_AT}myrix
> how can i recovery my without losing it after i broke my system (from .33 to .37)? I've also seen this message when reinstalling. But never lose data, i think it's a bit misleading. I think if the disks have wrong partitions, they will be repartioned and you lose the data, if the partition scheme is TNAS it only installs the system to the /-partition and data are untouched. See: viewtopic.php?f=76&t=423
TNAS: F4-220, 4GB Ram, TOS 5.1.37, 8GB System, 2x4TB IronWolf TRaid Btrfs , 1TB SSD-WDRed Btrfs
crisisacting
{L_BUTTON_AT}TMroy
Noticed that there's a newer 5.1.50 build available for the ARM based 211 device series @ https://support.terra-master.com/downlo ... uct=F2-211 (plus a mention of yet to be released 212 device series) … is there another release for ×64 imminent as well?
{L_BUTTON_AT}TMroy
crisisacting wrote: 25 Jun 2023, 17:21 Noticed that there's a newer 5.1.50 build available for the ARM based 211 device series @ https://support.terra-master.com/downlo ... uct=F2-211 (plus a mention of yet to be released 212 device series) … is there another release for ×64 imminent as well?
x64 system keeps updating. But version number between x64 and ARM could be slightly different. ARM series will not get special preferential treatment, please relax and pay attention to our update notice.
