TOS 5.1.37 (X86) is Released for Update
DERIKKU
Re: TOS 5.1.37 (X86) is Released for update
Post by DERIKKU »
{L_BUTTON_AT}TMroy
nope usbshare1 and 2 are in the network as shares (but an error comes when i will open this)
F5-221
TNAS 10TB
RAM 10GB
TMwuu
Post by TMwuu »
{L_BUTTON_AT}DERIKKU
You can try to clear the SMB access records and restart the SMB service.
topo01
Germany
Post by topo01 »
This is confusing in the opening post as this link "update to TOS 5...." takes me to TOS 5.1.24 and not to TOS 5.
TMRyan wrote: 27 May 2023, 18:39 Important Notes
F2-220, TOS 5.1.123 (8GB system partition), Docker 2.0.16 (Nextcloud, AdGuard Home), Terra Photos 2.0.13
It is recommended to reinstall 5.1.24, then update to 5.1.33-> 5.1.37.
TMwuu wrote: 28 May 2023, 18:12 You can try to clear the SMB access records and restart the SMB service.
Yes, try to plug in your USB drive, then remove it and check if the usbshare1 or 2 will disappear.
sports_wook
Post by sports_wook »
This nuked my system coming from 5.1.34. White loading screen on TNAS port and never loads. Checked before upgrading and there was 300 mb available on /
sports_wook
F2-220
sports_wook wrote: 28 May 2023, 23:23 This nuked my system coming from 5.1.34. White loading screen on TNAS port and never loads. Checked before upgrading and there was 300 mb available on /
tommi2day
Germany
Post by tommi2day »
on my t9-450 i was able to fix the boot issue using console port. There i saw the boot proces was on stuck because of missing grub files. Went into system bios and found the boot order set to the first HDD in the system. I changed it to the internal usb stick uefi partition. to change the boot order you need to disable the TOS first option. Now it started to operate and was greeting me with the update complete notice. I dont know if the boot order was intentional, but this how it works for me. No need to clear all disk as suggested.
Thomas
main: T9-450
fer_j_lop
Post by fer_j_lop »
TMroy wrote: 28 May 2023, 10:58
DERIKKU wrote: 27 May 2023, 23:05
network smb i have some folder:
(.deCompressDir_0b812568da4ba30bc002ace26544dc24)
(.update_6cf63d40d9af5463182da96e489889c1)
usbshare1
usbshare2
i found this folder only in smb.conf. i delete this in the conf file and the are gone away. after a reboot this shre folder are back in smb-conf. and no this folder are not exist in file system
Solution: This issue has been fixed since the last update 5.1.33. plug in your USB again, and then remove it, the usbshare folder will no more show again.
Good evening.
Same issue after the upgrade to 5.1.37. The two fake shared folders appear in Windows by SMB (.deCompressDir_0b812568da4ba30bc002ace26544dc24 and .update_6cf63d40d9af5463182da96e489889c1). They cannot be deleted because, even editing smb-conf to delete entries, they reapear again after reboot. No external USB disk connected.
Regards
UncleJohnsBand
Post by UncleJohnsBand »
I have the F5-221 and am trying to figure out where to see if I have enough free space to move to 5x.
You instructions say:
Go to "TOS > Control panel > System Info > Overview", and check free space from the item of "/"
I have no Overview.
I have just Hardware, Service Status, Resource Monitor and System Log.
