Scheduled task not running
The brand-new USB Copy not only provides common backup features, in order to realize offline backup and defend against threats from external networks, TerraMaster engineers have also additionally developed the USB auto-hide feature.
mithito
Re: Scheduled task not running
Post by mithito »
I managed to update the "next run" to the right date on the tasks and automatically add them to the scheduled tasks window doing these steps: edit the taks it, disable the schedule checkbox, save, edit the task again and re-enable the schedule checkbox.
TMwuu
Post by TMwuu »
{L_BUTTON_AT}mithito
You can try to disable and re-enable the app in the App Center.
mithito
Post by mithito »
Thanks for the suggestion @TMWuu.
I already did the trick of editing the tasks disabling and re-enabling the schedule, and it worked for all my tasks. They are running ok now. But if any one has the same issue I suppose your suggestion is a shorter way of fixing it.
gaz2k1uk
Post by gaz2k1uk »
On the latest version and auto run does still not work?
Setup:
System: F2-422
OS: TOS 5.1.79
HD: x2 6GB IronWolf 6TB (RAID 0)
Notes: 8GB System Partition!
Backup:
USB COPY: Seagate 8GB External Expansion HDD
Return to “USB Copy”
