DLNA media server: bad music track duration
chourmovs
Post by chourmovs »
Waiting for virtualbox to come back alive, I'm still trying to get an alternative to volumio as DMS(server) to serve music (only) files using UPNP/DLNA protocol to my DMR (renderer),
I was playing around with your multimedia server, it globally works but there is a big issue with file duration recognition that avoid skipping to next track, I can't play more than 1 track !
On two different DMC (controller: Uplay on Linux and Hificast on Android), all my FLAC and mp3 are announced to length 17 hours !!!
There's not much parameters to play with, could you provide a fix to what look like a wrong minidlna implementation
Thank you for your answer
TNas F2-220
Re: DLNA media server: bad music track duration
We will look into the case, and come back to you soon.
Hi chourmovs,
we tested several DMC on smart TV and computer with Windows OS, all MP3 and flac music playback well, we did not find the same issue of tracking duration. Would you check your DMC configuration and more other DMC devices?
chourmovs
Post by chourmovs »
I tried to uninstall reinstall and issue is still there, confirmed with two different DMC on Kubuntu and two other on android
Uplay
EezUpnp
I'm on tos 4.1.23 (after a clean reinstall) that make maybe the difference from standard situation (4.1.21)
TNas F2-220
Hi, would you send two of your sound tracks to support(a)terra-master.com, then we can try again on different DMC with your tracks?
