Swap off
XFNeo
Swap off
Post by XFNeo »
Hi! How to disable swap on my F2-423 with TOS 5.1.33 permanently?
I do swapoff -a but after reboot it is enabled again.
TMtina
Re: Swap off
Post by TMtina »
Hello, disabling the swap partition may affect the operation of your system, we do not recommend that you permanently disable the swap partition.
XFNeo
Re: Swap off
Post by XFNeo »
I have ordered additional sertified 16Gb RAM and I guess I dont need a swap with 20 gb of RAM.
TMtina
Re: Swap off
Post by TMtina »
If you want to permanently disable the swap partition, maybe you can find a professional operation method from the Internet. I think there are some commands that can help you complete this operation.
XFNeo
Re: Swap off
Post by XFNeo »
TMtina wrote: 25 Apr 2023, 21:45 If you want to permanently disable the swap partition, maybe you can find a professional operation method from the Internet. I think there are some commands that can help you complete this operation.
On common linux it is swapoff -a and remove swap from /etc/fstab
But in TOS there is no record in /etc/fstab about swap, and after swapoff -a and reboot TNAS, swap is enabled again.
How to disable swap permanently on TOS?
Return to “System Resources”
