[ ffmpeg51 ] Record, convert and stream audio and video
About : https://www.ffmpeg.org
Applicable TOS4:
Applicable TOS5: 5.1.13 or later versions
App download: https://tmnascommunity.eu/download/ffmpeg51
Required packages:
ModBase1
ffmpeg
With hardware acceleration via vaapi and qsv
Make sure you enable the correct driver for your platform to benefit the hardware transcoding
Provide ffmpeg branch 5.1.x
FFmpeg is the leading multimedia framework, able to decode, encode, transcode, mux, demux, stream, filter and play pretty much anything that humans and machines have created. It supports the most obscure ancient formats up to the cutting edge.
