[ Transmission4 ] A Fast, Easy and Free Bittorrent Client
About: https://transmissionbt.com/
Category:
Applicable TOS4:
Applicable TOS5: 5.1.29 or later versions
Applicable TOS6: 6.0.124or later versions
App download: https://tmnascommunity.eu/download/transmission4_okm
TOS4: http(s)://yournasip:port/modules//www
TOS5: click on Support & Help from app description inside the App Center
About
Easy & Powerful
Transmission is designed for easy, powerful use. We've set the defaults to just work and it only takes a few clicks to configure advanced features like watch directories, bad peer blocklists, and the web interface. When Ubuntu chose Transmission as its default BitTorrent client, one of the most-cited reasons was its easy learning curve.
Lightweight & Lightning Fast
Transmission has one of the lowest memory & resource footprints of any major BitTorrent client. Transmission's light overhead is one reason why it is so well suited for home NAS and media servers. Having been used by Western Digital, Zyxel and Belkin, Transmission gives truly impressive performance on almost any compatible hardware.
5k2gpce2
Re: [ Transmission4 ] A Fast, Easy and Free Bittorrent Client
Post by 5k2gpce2 »
{L_BUTTON_AT}outkastm
I had some issues on install. It looks like there are some ubiquitti dependencies on this installation, and it's preventing usage. Line 86 on 6.php for the webui folder. Can this be installed while the TOS Transmission App is also installed?
You are reffering to line 86 in 7.php This page is not used in the WebUI for transmission.
Regarding the paralel use with the official app, this should work if you adapt all the listening ports in one of the 2 apps
5k2gpce2
Post by 5k2gpce2 »
Found the issue, the default whitelist setting was preventing me from accessing the page.
dkaratasos
Post by dkaratasos »
I have around 200 torrents active on the installed 3.00 Transmission.
How do I go on this to make the change and also keep the active torrents?
e.g. Do I uninstall 3.00 and then install the 4?
Do I need to backup/restore something?
Thanks!
dianzisongyang
Japan
Post by dianzisongyang »
No amount of editing allows this to work. I tried changing the whitelist and nothing helps. never launch.
samius
Post by samius »
The application is not working. Rewritten from another application with many errors!
F4-424 Pro TOS 6.0.229
What exactly is not working? Not starting? No connection? Cannot be installed? Any error? Have you checked the log file? Can you provide some screenshot s to fix the issues if needed?
samius
Post by samius »
Hi, yes not starting. Start script (service) is not correct. And webui with errors, hasnt "apache.fw.png" and other :). And transmission webui dont work.
I completely remade this transmission4, with a fresh webui, sorry that based on your ttyd plugin...
Just download the app again and install it.
